Expedition PCB Trace Impedance - How do I show it?
sebmaster
Member level 1
Member level 1
Hello,
I am using Expedition PCB to lay out a board containing differential traces. I would like to check its estimate of the impedance, based on layer stackup and trace width, but cannot find out how.
I am pretty sure Expedition's 'Final Solver' calculates this, as the help files mention the equation it uses when discussing the Layer Stackup dialog. I have set the constraint in CES, and can also see my constraint in iCES, but there is no 'actual' counterpart, above or below my constraint, like there is with things like TOF Delay Match, etc.
How can I get Expedition to estimate the impedance of my differential traces, and see the results?
Sj
hello, sebmaster!
In CES --> Data --> Actuals --> Update All.
you can see the results in tables CES.
after update, CES --> Data --> Constraint Violations, you can see violations in a window.
