parameshwari
Newbie level 1
//3,4=gps
//9,5=gsm
//6,7=us
//9,10,11,12,13=rfid
//rx,tx=esp
//Changes should be done based on the output of previous program
#include "SPI.h"
#include "MFRC522.h"
#define SS_PIN 10
#define RST_PIN 9
#define SP_PIN 8
MFRC522 rfid(SS_PIN, RST_PIN);
MFRC522::MIFARE_Key key;
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "redmi"; // your network SSID (name)
char pass[] = "paramesh33";
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
static const int RXPin = 4, TXPin = 3;//gps
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);//gps
SoftwareSerial mySerial(9, 5);//gsm
const int pingPin = 7;
const int echoPin = 6;//ultrasonic sensor
//double rfid;
float lat1,lon1,lat2,lon2,lat3,lon3,lat4,lon4,lat5,lon5,amount;
int rvalue=0,uvalue=0,t1=0,t2=0,t3=0,t4=0,t5=0,km=10;
void setup()
Serial.begin(9600);
SPI.begin();
rfid.PCD_Init();
ss.begin(GPSBaud);
mySerial.begin(9600);
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD)
Serial.println("WiFi shield not present");
// don't continue:
while (true);
String fv = WiFi.firmwareVersion();
if (fv != "1.1.0")
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while (status != WL_CONNECTED)
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(1000);
server.begin();
// you're connected now, so print out the status:
Serial.print("You're connected to the network");
void loop()
if (!rfid.PICC_IsNewCardPresent() || !rfid.PICC_ReadCardSerial())
return;
// Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
// Serial.println(rfid.PICC_GetTypeName(piccType));
// Check is the PICC of Classic MIFARE type
if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&
piccType != MFRC522::PICC_TYPE_MIFARE_1K &&
piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
Serial.println(F("Your tag is not of type MIFARE Classic."));
return;
String strID = "";
for (byte i = 0; i < 4; i++) {
strID +=
(rfid.uid.uidByte[i] < 0x10 ? "0" : "") +
String(rfid.uid.uidByte[i], HEX) +
(i!=3 ? ":" : "");
strID.toUpperCase();
Serial.print("Tap card key: ");
Serial.println(strID);
if (strID.indexOf("E9:A3:DD:2B") >= 0)//1
t1=t1+1;
rvalue = rvalue+1;
if(t1%2==1)
Serial.print("parameshwari entered");
while (ss.available() > 0)
gps.encode(ss.read());
if (gps.location.isUpdated())
Serial.print("Latitude= ");
lat1=gps.location.lat();
Serial.print(lat1, 6);
Serial.print(" Longitude= ");
lon1=gps.location.lng();
Serial.println(lon1,6);
if(t1%2==0)
Serial.print("parameshwari is leaving");
lat2=gps.location.lat();
Serial.println(lat2, 6);
lon2=gps.location.lng();
Serial.println(lon2,6);
long distance = sqrt((lat1 - lat2) * (lat1 - lat2) + (lon1 - lon2) * (lon1 - lon2));
mySerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
mySerial.println("AT+CMGS="+917397170927"\r"); // Replace x with mobile number
mySerial.println("you travelled");// The SMS text you want to send
mySerial.println(distance);
mySerial.println("kilometers.");
amount=km*distance;
mySerial.println(amount);
mySerial.println("is reduced from your account");
mySerial.println((char)26);// ASCII code of CTRL+Z
}//1
if (strID.indexOf("38:86:8D:33") >= 0)//2
t1=t1+1;
rvalue = rvalue+1;
if(t1%2==1)
Serial.print("priya entered");
if(t1%2==0)
Serial.print("priya is leaving");
Serial.print(lat2, 6);
amount=km*distance;
}//2
if (strID.indexOf("E4:0A:BA:EB") >= 0)//3
t1=t1+1;
rvalue = rvalue+1;
if(t1%2==1)
Serial.print("preethi entered");
if(t1%2==0)
Serial.print("preethi is leaving");
amount=km*distance;
}//3
if (strID.indexOf("E4:0A:BA:EB") >= 0)//4
t1=t1+1;
rvalue = rvalue+1;
if(t1%2==1)
Serial.print("pradhiksha entered");
if(t1%2==0)
Serial.print("pradhiksha is leaving");
amount=km*distance;
}//4
if (strID.indexOf("E4:0A:BA:EB") >= 0)//5
t1=t1+1;
rvalue = rvalue+1;
if(t1%2==1)
Serial.print("rashmitha entered");
if(t1%2==0)
Serial.print("rashmitha is leaving");
amount=km*distance;
}//5
long duration, inches, cm;
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(10);
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
cm = microsecondsToCentimeters(duration);
Serial.print(cm);
Serial.print("cm");
if(cm<20)
uvalue=uvalue+1;
if(uvalue!=rvalue)
Serial.begin("someone entered illegally");
long microsecondsToCentimeters(long microseconds)
return microseconds / 29 / 2;
this is my code, while compiling i am getting error but i don't know what's wrong in that
