ranjbar_7
Junior Member level 1
hi
I have written this vhdl code and a script for it when i excute this scipt with design compiler i get this errors
but befor writing the scrpit i have Synthetized it with xilinx ISE there wasn't any errors!
what should i do can anone help me
Thanks in advance
errors:
Error: ./second.vhd:1: Syntax error at or near token '--'. (VER-294)
Error: ./second.vhd:64: The construct ''0' is not supported in this language. (VER-720)
Error: ./second.vhd:67: The construct ''1' is not supported in this language.
my vhdl code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity project1 is
Port ( data_in : in STD_LOGIC_VECTOR (31 downto 0);
output : out STD_LOGIC_VECTOR (32 downto 0)
end project1;
architecture Behavioral of project1 is
type d_array is array (0 to 32) of std_logic_vector(31 downto 0);
type t_array is array (0 to 32) of std_logic_vector(31 downto 0);
CONSTANT data_array : d_array :=(x"00000000",x"0000ffff",x"00000300",x"00000600",
x"01fd0000",x"0180c000",x"0000003b",x"01fee000",x"01fd4000",x"00000001",x"00010000",
x"00000002",x"00000700",x"000002a1",x"025d8cc0",x"0000001f",x"ffffffff",x"13131313",
x"12121212",x"ffff0000",x"14141414",x"00000004",x"15151515",x"1f1f1f1f",x"18181818",x"13131212",
x"02000000",x"14131313",x"13131314",x"00000200",x"14141313",x"13131312",x"13121212");
CONSTANT tag_array: t_array:=(x"00000000",x"00000001",x"00000002",x"00000004",x"00000008",x"00000010",x"00000020",x"00000040",
x"00000080",x"00000100",x"00000200",x"00000400",x"00000800",x"00001000",x"00002000",x"00004000",x"00008000",x"00010000",
x"00020000",x"00040000",x"00080000",x"00100000",x"00200000",x"00400000",x"00800000",x"01000000",x"02000000",x"04000000",
x"08000000",x"10000000",x"20000000",x"40000000",x"80000000");
begin
process(data_in)
begin
for i in 0 to 32 LOOP
if ( data_in=data_array(i)) THEN
output <= '0'& tag_array (i); else
output<= '1' & data_in ;
end if;
end loop;
end process;
end Behavioral;
and my script:
set my_files second.vhd
set my_toplevel project1
set my_clock_pin CLK
set my_clk_freq_MHz 100
set my_input_delay_ns 0
set my_output_delay_ns 0
set link_library ./osu025_stdcells.db
set target_library ./osu025_stdcells.db
define_design_lib WORK -path ./WORK
set compile_ultra true
analyze -f verilog $my_files
elaborate $my_toplevel
current_design $my_toplevel
link
uniquify
set my_period [expr 1000 / $my_clk_freq_MHz]
set find_clock [ find port [list $my_clock_pin] ]
if { $find_clock !=
Thanks in advance
errors:
my vhdl code:
library IEEE;
entity project1 is
end project1;
begin
process(data_in)
begin
end if;
end loop;
end process;
end Behavioral;
and my script:
link
uniquify
if { $find_clock !=
set clk_name $my_clock_pin
create_clock -period $my_period $clk_name
} else {
set clk_name vclk
create_clock -period $my_period -name $clk_name
set_driving_cell -lib_cell INVX8 [all_inputs]
set_input_delay $my_input_delay_ns [all_inputs]
set_output_delay $my_output_delay_ns [all_outputs]
compile -ungroup_all -map_effort medium
compile -incremental_mapping -map_effort medium
check_design
report_timing
report_timing -delay min
report_timing -delay max
report_timing -delay max > max_tim.rpt
report_timing -delay min > min_tim.rpt
write -f ddc -o ./Reports/myddc.ddc
write -f verilog -o ./Reports/netlist_verilog.v
write -f vhdl -o ./Reports/netlist_vhdl.vhdl
write_sdf ./Reports/Stndrd_Dly_Frmt.sdf
write_parasitics -o ./Reports/C_R_delays.spef
write_sdc ./Reports/sdc.sdc
