Excitation signal problem
neyshabouri
Newbie level 2
Newbie level 2
hi. please help me:
i want to import ascii table for excitation table( 2 pulse lightning). but when i run simulation appear following massage:
line 319: Error: lines 0-1500: function: table: time points not evenly spaced [ file signal4.csv<--? ]
Your information is a little sparse, but "time points not evenly spaced" type errors sometimes happen if a table is of the type which has values of both time and magnitude, and the time values are not incrementing in a way expected by the algorithm. For example, if the values are supposed to be evenly spaced and they are not, or if a time value is found to be less than the previous one, or sometimes if there is extra junk imported at the beginning or ending of the table.
1- how i can create new excitation signal step by step?
2- is cst software can analysis coupled thermal-electrical problem? ( for example a current source strike to structure and observe Temperature changes)
