There are two options AFAIK:
1. Program the user-defined function to produce the desired signal (you'll have to program it yourself i'm afaraid)
2. Use the Tabulated Excitation macro. For that you'll need a file containing a 2-column signal (time and amplitude vectors).
Then you re-scale the time base and amplitude in the macro dialog box.
