Circuit Learner
Junior Member level 1
I found a perfect DC-DC converter for my application, but it is rated for 36-75 volts input voltage.
I will use a lipo battery pack rated at max charge of 82 volts. The voltage will range from 66 volts to 82 volts as I use the battery.
Do you think I can get away with exceeding the maximum continuous voltage rating with this Dc-DC converter?
It won't be a big deal if it blows or burns up, so I am willing to take the risk if you think it will probably work.
Here is link to item.
https://www.mouser.com/ProductDetai...hrYxhSudp5mjKxZZHbIPAXYe8qzi31tVAS/70fEn6bw==
Data sheet link.
The DC-DC converter above is rated at 25 amps. I will only use a maximum of 10 amps and probably lower if that has any significance.
Data sheet link.
