FreshmanNewbie
Advanced Member level 1
I have an IC, whose input GPIO 's absolute maximum rating is Vcc+0.5V.
In a scenario, I will not be giving power (Vcc) to the IC. But the GPIO will be having 3.3V as the input.
In this case, would the IC or the IC pin will be damaged? Since, Vcc + 0.5V = 0V+0.5V = 0.5V. But the pin is having 3.3V.
Since, 3.3V is greater than 0.5V, my IC pin will get damaged ?
From my understanding, the main objective of giving the absolute maximum rating as Vcc+0.5V, is to not damage the internal ESD clamping diode that is internal to the pin. So, I am thinking like, it doesn't matter if we exceed the absolute maximum rating input of the pin, but we need to make sure that the current into the pin is very small so that the diode isn't damaged. But there's no current limit mentioned for the pin. Am I correct?
So, I am confused.
To summarize my questions:
1. Why is absolute maximum rating given only in terms of voltage and not current?
2.
So, I am confused.
2.
