exam quetion please help
rafia123
Newbie level 3
Newbie level 3
Describe, using VHDL, a 4-bit parallel load shift register. The register is to have a synchronous load signal (L) and an asynchronous reset (CLR) and will function synchronously using a clock (CLK) signal. The system has a serial input (SIN) a 4-bit parallel input bus ( D[3:0] ) and a serial output (SOUT).
if you dont know VHDL ... do you know digital electronics /schematics/ ?
