Exact alternative of HR911105A RJ45 connector
ogulcan123
Member level 5
Member level 5
Istanbul, Turkey
Hi all,
I'm looking for the alternative of HR911105A which will have exactly the same footprint (I actually don't know if such a thing is possible).
This connector is really nice and small, so I will use it in my design. However it doesn't exist in big distributers such as digikey, farnell, mouser etc.
Cheers,
Ogulcan
Yes sir... That's for sure. I may find it spending my entire week on that... well... if exists.
Maybe someone else faced the same issue before and point me to the component of exact footprint.
Are you likely to be ordering lots of these?
If so you get the supplier to find a matching alternative, then you just double check the dimensions.
We will order around 10-20 for development and a couple hundred after development, but I could not find a matching alternative yet..
What I mean by the matching alternative is the exact copy (at least of its footprint).
I guess, most major manufacturers have a RJ45 jack with this footprint (10/100 Base-T, THT, tab down, 2 LEDs). I'm e.g. using Wuerth 74990111215A. https://katalog.we-online.de/pbs/datasheet/74990111215A.pdf
Thanks FvM, that's a pretty close design, seems like the LED pins are drawn wrong (of course not, obviously)
Here is my comparison between the two..
