EW AVR and interrupt ? - Didn't operat...
elcielo
Full Member level 6
Full Member level 6
timer0_ovf_vect
unsigned int g_usec;
void TimerInit(void)
TCCR0 = 0x00; //stop
ASSR = 0x00; //set async mode
TCNT0 = 0xC6; //set count
OCR0 = 0x3A;
TCCR0 = 0x01; //start timer
TIMSK = 0x01;
void delay(unsigned int us)
g_usec = 0;
if (us>0) while(g_usec<us){;}
#pragma vector = TIMER0_OVF_vect
__interrupt void TIMER0_OVF_interrupt (void)
TCNT0 = 0xC6; //reload counter value
g_usec++;// 1 uSec/one
void main(void)
delay(255); <-operate
delay(10000); <-didn't oprate
Didn't operat...
How I do check option ?
Atmega 128
option -h must not be defined more than once
Option -H must not be defined more than once: -H1895
+----- what ?
timer0_ovf_interrupt
hi .. i am using delay routine based on topis described here:
Works fine for me and does not require timer ... in my app i am using timers for other purposes ...
mine looks like:
void delayus(unsigned int us)
while(us--) __delay_cycles(10) ;
you have to calculate delay constant (10 in my case) to match you hw .. iow osc freq. you need to include inavr.h
for your code .. first of all ... i would start timer by delay routine. in your code timer is running all the time and you are wasting mcu time by executing not neccessary interrupt. other thing ... your g_usec is not safe ... it overflow over int value(0xffff) after some time ... this can cause strange behavior
regards
cancel
avr interrupt tcnt0
OCR0 = 0x3A;
TIMSK = 0x01;
g_usec = 0;
void main(void)
Didn't operat...
Atmega 128
Imagecraft C compiler operate good.
Maybe
g_usec++;// 1 uSec/one <--It's overflow...
tcnt0 in avr
use :
volatile unsigned int g_usec;
