Randallman
Newbie level 3
Looking for a selectable 1-10 event counter with a selectable time of 1 4 8 and 16 hours.
So basically a rotary switch with 10 positions to select the count and a rotary switch with 4 positions to select the time between events.
When the selected count is done then set an output pulse to and NPN open collector transistor rated for 100mA for 1 second, then start selected timer 1 of 4 positions 1, 4, 8, or 16 hours when timer is done reset counter and start again.
I am looking to use either common timers like the 555 556 or other timer chips that are long delay would like to use common counter chips like the 4017, no digital displays required. Just keep it simple with two rotary selectors.
If anyone has such a circuit or can direct me to someone like an electronics consultant it would be appreciated.
