ETSI output power question
chihhao
Full Member level 4
Full Member level 4
etsi output power
HI
Can anyone tell me the output pwoer tolerance in normal & extreme
condition.
GSM PCL 5 = 33dBm +-??
DCS PCL 0 = 30dBm +-??
PCS PCL 0 = 30dBm +-??
Thank you very much.
normal: +/-2
extreme: +/-2.5
According to the latest GSM 3GPP TS 05.05 spec:
GSM PCL 5 = 33dBm +/-3dB nominal and +/-4 extreme
DCS PCL 0 = 30dBm +/-3dB nominal and +/-4 extreme
PCS PCL 0 = 30dBm +/-3dB nominal and +/-4 extreme
and +/-2dB nominal and +/-2.5 extreme (different class)
