Antonio_Magma
Full Member level 2
I have a chip module that accepts host interface of either:
1) MII PHY
2) GPSI PHY
3) MII Host/DTE
1) I know this is related to the typical LAN or Ethernet connection. How do i implement this?
Do i only need a PHY transceiver such as the KENDIN KS8721B and a RJ45 jack?
I've seen things such as the LinkCom LAN1102 10/100 BASE-T single port surface mount magnetics together with the PHY transceiver chips. What are they for? Line isolation? Do i need them or can i just function the the PHY transceiver?
2) Don't know what is the 2nd one.
3) MII host/DTE. Does it mean that i can use any interface for the DTE, such as the serial port? Which is much simpler than option (1)
Added after 1 hours 32 minutes:
Just found out the 2nd one is General Purpose Serial Interface.
Is this the same serial interface we use to communicate with our COM ports?
1) MII PHY
2) GPSI PHY
3) MII Host/DTE
