[SOLVED] Ethernet Inteface for AVR microcontroller
vru
Newbie level 3
Newbie level 3
Hi All,
I am working on school project.
I am using Atmega128 RF A1 , 8 bit microcontroller and plan to interface to a ethernet module which includes wiznet w5100 embedded ethernet controller.
I need to gather data from a number of devices to the main server using internet.
I know that We can control a device via a web browser. But I am not sure how?? to go about with this.??
Can Anyone help with any links or documents or an idea/concept/approach for the same.
Appreciate your help.
you want to design data acquisition system...
does your ethernet module contain serial port?
---------- Post added at 21:18 ---------- Previous post was at 20:56 ----------
u have to read the data sheet carefully!! i just downloaded n read it
u can interface it with ur microcontroller throught serial port of the microcontroller, the wiznet chip suppot serial to ethernet.
here is a suggestion to implement ur data acquisition system
recive ur data through uc's ADC then send it to the ethernet module then send it to ur server !
Thank you for your reply.
Wil look into it again and keep you posted.
