szekit said:how does one estimate offset voltage in the design process (i.e., opamp)?
meghna said:So basically two things affect the calculation of offset voltage; First is W & L mismatch and second is threshold voltage mismatch. So W & L mismatch can be reduced by increasing area. What's abt threshold voltage mismatch? How can it be reduced? Does it depend on the area?
meghna said:u r right.. common centroid takes care of it!
So we can conclude that Vt mismatch does not depend on area?
cretu said:The offset of a diff input pair is proportional with 1/sqrt(W*L)
rgds
Check for example the link to the pdf file that I have in my previous message. That should explain a little bit..and better that I canipsc said:cretu said:The offset of a diff input pair is proportional with 1/sqrt(W*L)
rgds
Hi cretu,
How did you get this equation?
Regards
q0w1e2r3 said:so,how can i get the offset value(input-referred) when i use candence?
