Estimated cost of high volume PCB assembly
question_asker
Newbie level 1
Newbie level 1
I am looking for a rough estimate (rule of thumb) for the cost per pin or cost per board of high volume PCB assembly. I can only find the costs for small prototype productions when searching the internet. By high volume I mean >10k boards. The boards are very small and portable, because they are going to be wearable. It would also be of interest to me wether assembly would take place in China or anywhere else.
Board specs:
  • [quantity: 10k+]
    [method: SMD only]
    [pins per board: ~105]
    [board size: 30mm²]
    [double sided soldering]
Furthermore, it would be helpful if you could provide an estimate for testing costs per hour for such boards. I don't take into consideration that there are costs upfront for software and fixtures etc, I just want to know a rough estimate of what testing will cost hourly.
I think there are just too many factors to give you a "rule of thumb". You also have to consider: pin pitch; number of components; standards; etc. Also. testing is not priced "per hour", it's per board.
I suggest you just contact several PCB assemblers; they can probably give you an answer.
