ESP8266MOD response not showing
imranahmed
Advanced Member level 3
Karachi,Pakistan
Please let me know about response of ESP8266MOD is not showing on Serial Monitor I set baud rate to 9600 but still not showing response but program is running well, data is transmitting to database successfully, I need responses of every AT command he sends.
#include <SoftwareSerial.h>
#define RX 2
#define TX 3
#define DEBUG true
String AP = "****************";
String PASS = "**************";
String sendData = "";
int sendVal;
String ROW1 = "", ROW2 = "";
SoftwareSerial espSerial(RX, TX);
void setup() {
  Serial.begin(9600);
  espSerial.begin(9600);
  pinMode(8, INPUT_PULLUP);
  espData("AT+RST", 1000, DEBUG);                      //Reset the ESP8266 module
  espData("AT+CWMODE=1", 1000, DEBUG);                 //Set the ESP mode as station mode
  espData("AT+CWJAP=\"" + AP + "\",\"" + PASS + "\"", 1000, DEBUG); //Connect to WiFi network
  delay(2000);
void loop() {
  sendData = "GET http://"HERE IP ADDRESS"/fileapi.php?ROW1=123&ROW2=878";
  "&ROW1=" + ROW1 +
  "&ROW1=" + ROW2;
  espData("AT+CIPMUX=1", 1000, DEBUG);
  espData("AT+CIPSTART=0,\"TCP\",\"HERE IP ADDRESS\",80", 1000, DEBUG);
  espData("AT+CIPSEND=0," + String(sendData.length() + 4), 1000, DEBUG);
  espSerial.find(">");
  espSerial.println(sendData);
  Serial.print("Value to be sent: ");
  espData("AT+CIPCLOSE=0", 1000, DEBUG);
  delay(2000);
String espData(String command, const int timeout, boolean debug)
  Serial.print("AT Command ==> ");
  Serial.print(command);
  Serial.println("     ");
  String response = "";
  espSerial.println(command);
  long time = millis();
  while ( (time + timeout) > millis())
    while (espSerial.available())
      char c = espSerial.read();
      response += c;
  if (debug)
    Serial.print(response);
  return response;
hello,
you are doing string=char
store the char at the location pointed by response
and increment this pointer for next char
pay attention :
* to init the size of string response .. to the maxima possible
* a string must have a zero value as terminator
   string reponse="                                           ";
or declare a char table and init it, with zero value
char response[20];
for (i=0;i<20;i++) response=0;
     *(response++)= c;
