dr pepper
Advanced Member level 1
I have a Esp8266 on a machine monitoring the water flow & temperature for water cooled brakes.
It works for a couple of days, but then crashes.
If I run the code on a Esp on the bench near the router it works fine.
The signal according to the Esp is around -82dB, googling signal strength tells me that this can cause wifi to drop packets.
Is there a way I can tweek the webserver code to cope with this, or do I need a massive antenna, I allreay have a +9dB whip.
