[SOLVED] ESP8266-01 Interrupts
sairfan1
Full Member level 1
Full Member level 1
Regina, Canada
I'm trying to setup interrupt in arduino based environment using board ESP8266-01, based on help i found on different sites i wrote following code, but when i program my device it continuously shows interrupt message "Interrupt Ocurred: 1" on serial monitor, while same program running if i pull down the pin it shows "Interrupt Ocurred: 0" that means I'm using correct port and it state changes when i do it on hardware, I pulled up pin externally as well, I also tried same program on NodeMCU for different input pins
C:
#include <ESP8266WiFi.h>
const int InterruptPIN = 2;
volatile byte isrInterrupt_A = 0;
void ICACHE_RAM_ATTR IsrInterruptFunction();
void TestInterrupt();
void setup()
   Serial.begin(115200);
   pinMode(InterruptPIN, INPUT_PULLUP);
   attachInterrupt(digitalPinToInterrupt(InterruptPIN), IsrInterruptFunction, FALLING);
   Serial.print("Ready");
void loop()
    if (isrInterrupt_A = 1) {
      TestInterrupt();
      delay(1000);
void IsrInterruptFunction() {
  isrInterrupt_A = 1;
void TestInterrupt(){
  Serial.println("Interrupt Ocurred: ");
  Serial.println(digitalRead(InterruptPIN));
  isrInterrupt_A = 0;
Do you mean by continuously as happening occasionally, or precisely at a regular interval of 1s? The first scenario would make more sense, since being internal pullups, 'weak' logic inputs, it would be susceptible to the handling you are probably doing.
What i expect from code, that when i press button that connects pin 2 to GND it should trigger the interrupt, that is because i pulled up pin 2 internally (thought i also tried external pull up) and i set pin 2 to trigger interrupt on falling edge that means when i push button to ground it should trigger the interrupt and serial monitor should show "Interrupt Ocurred: 0"
But what happens when i turn on the ESP without any interaction serial monitor prints "Interrupt Ocurred: 1" after every 1 second, that means pin 2 is properly pulled up, and its not falling edge but still interrupt was triggered.
Ahh found the issue, while writing reply to you i realized i used assignment operator instead of equal so i change isrInterrupt_A = 1 to isrInterrupt_A == 1 and it works, thanks,
