htekin42
Member level 2
Hi every body,
I am using ESP32-wroom-32E module and I need it to power it with 18650 Li-Ion battery. It should work like this,
- When there is power input, it should power from power input and charge battery
- if battery is fully charged, it should cut-off battery charging.
- if there is no power input, it should supply from battery.
I am planning to use 18650 Li-ion barttery in parallel to increase the current capacity. I will use 18650 Li-ion with capacity of 2000mAh and 3 or 4 in parallel to get 6000mAh - 8000 mAh.
Any suggestion or reference design will be helpful.
Thanks.
Best Regards.
Thanks.
Best Regards.
