4tuty
Member level 3
TTGO T-DISPALY ESP32 DEV Board for Arduino BLE WIFI LCD
TTGO ESP32 T-Display development board for Arduino, based on the ESP32 microprocessor (32-bit dual-core) and integrates a WIFI connection 802.11 b/g/n, Bluetooth and with a 2.4cm LCD screen.Compatible with the Arduino development environment.Delivered with: 1 LilyGO ESP32 T-Display v1.1 TTGO...
www.passion-radio.com
Hi, i am using the above said TTGO esp32 board with display,
If i connect the board via USB type C cable the display is ON, but if i give regulated 5 volt power supply the display is in off state. I have to press the push button which is next to 5V pin. I need it to be ON when i switch on the device.
