davidpan
Newbie
I have a signal A and I would like to set constraint to the output (DO) check such that, for example, if in the symbolic cycle 1, A = 1, then I want to ignore output check for symbolic cycle 2 & symbolic 3, and only check the output at symbolic 4, else if in the symbolic cycle 1, A = 0 AND in the symbolic cycle 2, A = 1, then I want to ignore output check for symbolic cycle 3 & symbolic 4 , and only check the output at symbolic 5.
Is there a way to do it? If so how should I write the set_constraint command?
