psm1234
Dear all, please could you explain me function of ESD protective diode? This diode is connected to ground and after some higher input signal, which is not allowed, this overcurrent is going through the diode to ground (this overcurrent is divided to two sides - ground and normal way, so it is lower as if the protective diode is not there).
Is it truth?
Thank very much
Is it truth?
Thank very much
