Rajinder1268
Full Member level 3
I have selected a FTDI231xs USB to UART device. Operating at USB 2.0 full speed 12Mbps. Power to the FT231x will be from 5V (filtered VBUS), then using the internal 3V3 LDO to power up the microcontroller etc.
I need to add ESD protection for 2 x data lines (D+/D-) and 5V. I realise the max capacitance allowable (line to line) is 5pF for USB 2.0. This should not be exceed, otherwise rise fall times can be affected. The ESD must be adequate for EN6100-4-2.
My question is
1. Voltage requirement for the ESD TVS array as it needs to protect the 5V and 2 x datalines
2. Clamping voltage required
3. Working voltage
4. Uni or bi-direction TVS array?
Is there anything else to consider. I have seen the RClamp0503F but not sure as it is for OTG applications.
My question is
3. Working voltage
