alpha999
Newbie level 3
Is there any way to protect a normal diode between two pads that is intended for temperature measurements ?
If normal esd diode to vcc/gnd and power clamp protection style is used there will always be the problem that if the device is off and you inject a current for calibration of the temperature diode that the current can go parallel to the temperature diode through the ESD diode to VCC and then GND and so influencing the measurement.
