Prabhakarankft
Member level 3
- Joined
- Jun 22, 2019
- Messages
- 54
- Helped
- 0
- Reputation
- 0
- Reaction score
- 4
- Trophy points
- 8
- Location
- Chennai, India
- Activity points
- 623
Hello Everyone!
I have a Microcontroller Board to control some relays(Around 80 - 120 Numbers) with the help of CD4094 . Relay driver board is separate and it is 5 Meter in distance from the Microcontroller Board..
Now I have to send data to Shift registers-CD4094 which are 5 meters away from the Microcontroller Board. What is the best way to send data in such situations .
Kindly give me your best ideas to get error free solution!
MCU IO Pins @3V3-----> 74HC541(Buffer IC) ----------------------------5 Meter Shielded Cable------------------------------->74HC541(Buffer IC)-->CD4094-->Relay driver parts(ULN2803)
I have much confusions on my mind.
1. If we use lengthy cables it will act as a Antenna! If yes what are all the precautions to do?
2. ESD protection for CD4094 IC. MCU is working at 3.3V. Logical signal are feed to the 8 Core shielded Cable. Any surge may appear at the CD4096 End??
3.I plan to use Buffer ICs on both ends to receive(Relay Board) and send data from the MCU. Reason to use buffers,it resists ESD.
Great suggestions are appreciated. I am ready to correct the errors!
