T
Thanks,Wrist strap (with regular testing) is sufficient for many workshops.
Thanks,Loops are for charge-neutral environments. You are
looking for charge -equalization- and that can happen
along any conductor. The return path is the universe.
As long as nobody puts an earthed chassis on the floor, and as long as nobody wears any kind of shoe other than a 100k Ohm shoe, everyone will be safe and the equipment will be ESD free.Thanks,
So in the environment with the aluminium floor tiles that are connected to earth via 2 MegOhms, and the resistance through the soles of their shoes being 100kOhms, the person should not even need a wrist strap?
Thanks, presumably you are talking of electric shock hazard here?As long as nobody puts an earthed chassis on the floor,
Yes i know what you mean, but when you are busy, and constantly going to and from the bench multiple times each day, its easy to once forget to put the wrist strap on when touching something...and zapp...damaged.As Hexreader states, you really are expending your efforts on chasing ghosts, the time proven solutions to a trivial problem are all you need
Thanks....the alu coated floor is earthed via 2 megohms.An earthed aluminium floor would be akin to a wet floor as far as electrocution hazard goes
thanks, so you are assuming that the legs of the workbench are conductive and the components are not on high resistance (though still "ESD safe") materials?Look at it this way: You make an all metal conductive floor and charge it up to 100KV, on it you place a workbench and on the workbench you place your static sensitive devices. Will they be damaged by touching them?
(answer - in case you haven't worked it out is no, because they are at the same potential as their surroundings and the person touching them)
Your workbench is supposed to be grounded via 1M already.thanks, so you are assuming that the legs of the workbench are conductive and the components are not on high resistance (though still "ESD safe") materials?
Thansk yes, we dont have overall ESD flooring, we just put PCBs into the pink plastic ESD bags when we transport them from place to place.Consider that components and modules are handled at work benches but also transported through the room.
Thanks, the thing is, when wearing a single point wrist strap, where is the loop for the charge to flow in as part of the discharge process of the static charge?
