T
treez
Hello,
We have to use a temporary hut for some electronics work. There is no ESD flooring. The floor appears to be chipboard with a clear varnish coating. Therefore, I stuck a few overalapping 1 metre strips of 5cm wide aluminium tape to the floor in front of the bench where I stand and work. I soldered a wire to these strips, and then soldered 10 MegOhms into this wire in series , and then wired from the 10 Meg into a mains earth socket.
Is this a valid way to tackle ESD , and could it be considered dangerous, bearing in mind that we work on live mains now and again?
(we also have an ESD mat on the bench and ESD wriststraps connected to this mat)
