Vraj
first thing i need is less RPM .
https://www.amazon.com/Toro-Beast-520KV-Brushless-Motor/dp/B00WIM7BMI?ie=UTF8&*Version*=1&*entries*=0
i found that bldc motor has rating on kv. which means if i give 2v to 520kv motor , it's RPM will be 1040.
so for achieving low rpm, i have to apply low voltage and high current. i also need high discharing rated batteries.
but minimum voltage for ESC is 7.4v. can i get maximum power at this minimum voltage?
i can't reduce RPM by mechanical gears. because the is no space left.
i need low rpm for more torque.so maximum power of bldc is required.
