Errors when using IC50 under Fedora Core 2
qslazio
Full Member level 3
Full Member level 3
IC50 under Fedora core2
i've install Cadence IC50 on Fedora Core 2.
But when i enter IC50 by typing icfb&,it carries out a warning:
"incorrectly built binary which accesses errno or h_errno directly. Needs to be fixed."
And when i compile a new techfile using a .tf file.
It shows (Red hat 8.0 doesn't show this warning)
"Loading techComp.cxt
Compiling class 'layerDefinitions'....
*WARNING* Layer M5DUM was not created since its layer number 128 is a reserved layer.
*WARNING* Layer M5SLOT was not created since its layer number 129 is a reserved layer.
*WARNING* Layer M6SLOT was not created since its layer number 130 is a reserved layer.
*WARNING* Layer HTNWL was not created since its layer number 131 is a reserved layer.
*WARNING* Layer EXCLU was not created since its layer number 132 is a reserved layer.
*WARNING* Layer ESDIO was not created since its layer number 133 is a reserved layer.
*WARNING* Layer DMPNP was not created since its layer number 134 is a reserved layer.
*WARNING* Layer PDC was not created since its layer number 135 is a reserved layer.
failed to load technology file '....../XXX.tf' "
So who can tell me how to fix it thanks very much!
For your first question, i.e., h_errno,
Add this environment, assuming csh
setenv LD_ASSUME_KERNEL "2.4.1"
you should try IC5032
please kindly do not start unnecessary threads..there are lots of threads relating to cadence ic installation ..u can just browse through them.by the way ur problem will be solved if u set the variable
setenv ld_assume_kernel=2.4.1
in bash.
regards
amarnath
I supposed that in bash it should be like this:
export LD_ASSUME_KERNEL=2.4.1
but still there is problem with the kernel version i think
when i tried ic 5.1 wavescan was not running i mean i was not able to run simulations using analog environment
