Errors in IC50 simulation concerning transistor parameters
zrl
Newbie level 1
Newbie level 1
IC50 simulation problem
I compose schametic with the analoglib components. when I simulate the circuit, it gave me errors on transistor model parameters being blank or not set. I did set W and L in the mos transistor's property.
can anyone guide me through schametic-composer part for correct simulation??
I simulated everything OK in school with IC4.X.X.
thanks alot.
Re: IC50 simulation problem
please provide the entire error message. One possible error is that the model library path isn't set correct in analog design environment. but we need detailed information about the error.
greetings,
hqqh
