[SOLVED] Error with creating a equation in ADS with the variable already defined on the schematic as Var
henry kissinger
Member level 2
Member level 2
I am trying to create a equation to plot the eye diagram from the voltage node Vout
As I define the equation, it tells me that the "Tbit" is not defined!?
I wonder why because I have already defined it on the schematic in the 'Var" icon
Does anyone know?
Tbit as an instance property may not create a Tbit in the variables list? Or maybe evaluation of the var object has some prior issue blocking it?
