Error when launching Allegro 14.2 (Cannot open message file)
majnoon
Full Member level 5
Full Member level 5
allegro14.2
I recently experiencing problems with Allegro 14.2. When I try to start the software it gives a message:
"Cannot open message file, env path is possibly set incorrectly.
critical variables not set in the env file, ...."
I have PCBENV folder and I copied env file into C:\Cadence\PSD_14.2\share\pcb\text but still gives the same message any idea??
It used to work poroperly.
Thanks
allegro cannot open message
Looks like you need the missing file ...
I advise you to use v15.0 instead !!! Very good one !
