OrangeHalo
Junior Member level 2
Hi all,
I am doing Monte Carlo simulation with IC617 and TSMC 180nm PDK. I am using ADE explorer to do the simulation. But the simulation failed with the following error:
ERROR (EXPOLRER-5052): Monte Carlo run stopped because no statistical data generated for the test.
I ran different corners and it turned out that those simulations are running smoothly. But I am not sure about how to set model sections in MC simulation.
Here is how I set the MC model sections:
Basically I use typical mosfet, bipolar transistor and resistor to build a bandgap reference circuit. And I do set the models to be those with mismatch characteristics. I think the model sections in the screenshot are enough to do the simulation.
Here is how I set the MC simulation:
Here is how I set the output signal:
Could someone please help me with it or give me some hint?
Thanks in advance.
Best,
OrangeHalo
Thanks in advance.
Best,
OrangeHalo
