Error when converting graphic LCD routine to CCS C Compiler
Sobakava
Full Member level 6
Full Member level 6
PIC C Code Conversion
I'm converting a graphic LCD routine to CCS C Compiler:
void LCD_PutPixel(unsigned char x, unsigned char y, unsigned char Set)
unsigned int XY;
unsigned char bitByte;
   XY=0x200;
   XY=XY+(y*40);
   XY=XY+(x/6);
   LCD_SendData(XY & 0x00FF);
   LCD_SendData(XY>>8);
   LCD_SendCmd(0x24);      	//pointer set
   bitByte=5-(x % 6);
  Set? bitByte|=0xF8: bitByte|=0xF0;
   LCD_SendCmd(bitByte);   //0b1111SXXX , s is set/reset, xxx is bit
   ///number xxx
   //(Each memorybyte i six graphics bits (pixels))
CCS Did not recognized this line:
is it the same thing with:
   if (Set==0) { bitByte|=0xf8;}
   else
      {bitByte|=0xf0;}
or should it be:
   if (Set==1) { bitByte|=0xf8;}
   else
      {bitByte|=0xf0;}
Re: PIC C Code Conversion
The last of your examples is almost correct, but not completely the same as Set?.
is it the same as:
if (Set)
   bitByte|=0xF8;       //If Set is true (not zero), i.e. 1, 2, 3 etc.
else
   bitByte|=0xF0;       //If Set is false (zero).
You can also write if (Set != 0) it's the same thing as if (Set)
But you should not write if (Set == 1), that's not the same, because the if statement is true for every value different from 0, not only 1, but also 2, 3 etc.
Maybe Set can have the value 2, then the if statment should still be true, like it is when you write Set?
