error using Modelsim
Binome
Full Member level 3
Full Member level 3
Lyon, France
I'm using Modelsim to simulate my vhdl design.
I'm using the GUI on Windows 7 pro x64. Every time I run a new simulation a popup appears. The title of the window is "Error in Tcl Script" (I don't use that) then the message is "Bad sequence in.main_pane.memory.interior.cs.body.list.lwchildsite.clipper.canvas.sfchildsite.tree, aborting query"
I can't find anything about this on the internet. Does someone know what I have to do?
Difficult to say....
1> Uninstall and then re-install Modelsim. If this doesn't fix the issue...
2> Close the current project. Copy only the source files and create a new project and then run a fresh simulation, else...
3> Post in Modelsim forum with details of the error msgs.
Thank you. It's not bothering enough to try to reinstall Questasim so I won't do that for now.
