Error running post layout simulation
naalald
Full Member level 4
I'm running post layout simulation with cadence and I'm getting this error:
ERROR (SFE-23): "input.scs" 63: re1 is an instance of an unidentified model M2.
I tried in two ways: First, I ran QRC for R and C and, second I ran just for C. The first time I got this error but the second time no errors and post layout simulation was done successfully.
So, there must be sth wrong with the resistance model.
Does anyone know what the problem is and how I can fix it?
Thanks.
In the first run - perhaps you had enabled - parasitic resistor models.
This is available on the Netlisting Options tab..
Solution - either keep the model printed as a comment - else - do not enable this.
