Error response from server when sending a POST request using SIM800
electronicsIUST
Member level 3
Member level 3
Error Response from server whensending POST request using sim800
I want to send data to a server using POST method with sim800. When I use POSTMAN, data is sent correctly but when I use the same headers of POSTMAN in the sim800 error is returend from the server and below message is recieved:
HTTP/1.1 200 OK
Server: nginx/1.14.0 (Ubuntu)
Date: Thu, 01 Nov 2018 21:48:40 GMT
Content-Type: text/html; charset=utf-8
Content-Length: 5
Connection: keep-alive
Error
CLOSED
what can be the problem?! I use the below AT commands sequence in sim800:
AT+CGATT=1
AT+CIPMUX=0
AT+CSTT="APN","USER","PASS"
AT+CIICR
AT+CIFSR
AT+CIPSHUT
AT+CIPSEND=20
POST /post HTTP/1.1
Host: **.**.***.***
Content-Type: application/json
Content-Length:23
{"postkey":"postvalue"}
Re: Error Response from server whensending POST request using sim800
Hello,
I see the answer of 200 HTTP code (means request received OK).
But after, it seems that something happens with your nginx server.
Have you tried to send requests to another server instead. just to verify that your code with SIM8080 works well with other servers.
Hello,
I found that the problem was from the server side that returned error response.
