sgtom
Junior Member level 1
when i try interfacing my stopwatch using 8052 with the PC this is the error we get:
Build target 'Target 1'
compiling microcontroller programming.c...
MICROCONTROLLER PROGRAMMING.C(123): error C267: 'serial': requires ANSI-style prototype
Target not created
if u can pls help me the code:
that is the original code:
#include<reg51.h>
#define msec 1
unsigned int sec1,sec2;
int sec1_1,sec1_2,sec2_1,sec2_2;
unsigned int
digi_val[10]={0x40,0xF9,0x24,0x30,0x19,0x12,0x02,0xF8,0x00,0x10};
sbit dig_ctrl_1=P1^0;
sbit dig_ctrl_2=P1^1;
sbit dig_ctrl_3=P1^2;
sbit dig_ctrl_4=P1^3;
sbit start_pin = P1^4;
sbit stop_pin = P1^5;
sbit reset_pin = P1^6;
int s,t;
void mplex_delay(unsigned int time)
int i,j;
for (i=0;i<=time;i++)
for(j=0;j<=50;j++);
void digi_out(unsigned int current_num)
P2=digi_val[current_num];
mplex_delay(msec);
void display(unsigned int dig1,unsigned int dig2)
sec1_2=dig1%10;
sec1_1=dig1/10;
sec2_2=dig2%10;
sec2_1=dig2/10;
TMOD=0x01;
TL0=0xFF;
TH0=0xDB;
TR0=1;
while(TF0==0)
dig_ctrl_1 = 1;
dig_ctrl_2 = dig_ctrl_3 = dig_ctrl_4 = 0;
digi_out(sec1_1);
dig_ctrl_2 = 1;
dig_ctrl_1 = dig_ctrl_3 = dig_ctrl_4 = 0;
digi_out(sec1_2);
dig_ctrl_3 = 1;
dig_ctrl_2 = dig_ctrl_1 = dig_ctrl_4 = 0;
digi_out(sec2_1);
dig_ctrl_4 = 1;
dig_ctrl_2 = dig_ctrl_3 = dig_ctrl_1 = 0;
digi_out(sec2_2);
TR0=0;
TF0=0;
void serial()
TMOD = 0x20;
TH1 = 0xFD;
SCON = 0x50;
TR1 = 1;
while (1)
SBUF = sec1;
while(TI==0);
TI = 0;
void serial1_1()
TMOD = 0x20;
TH1 = 0xFD;
SCON = 0x50;
TR1 = 1;
while (1)
SBUF = sec2;
while(TI==0);
TI = 0;
void main()
while(1)
start:
start_pin = 1;
stop_pin = 1;
reset_pin = 1;
dig_ctrl_1 = 0;
dig_ctrl_2 = 0;
dig_ctrl_3 = 0;
dig_ctrl_4 = 0;
P2 = 0xFF;
s = t = 0;
while(start_pin == 1)
display(0,0);
stopwatch:
for (sec1=s;sec1<=99;sec1++)
if (stop_pin == 0 )
break;
for (sec2=t;sec2<=99; sec2++)
if (stop_pin == 0 )
break;
t=0;
display(sec1,sec2);
serial(sec1);
serial1_1(sec2);
stop_pin = 1;
s = sec1;
t = sec2;
while ( start_pin != 0 && reset_pin != 0 )
display(sec1,sec2);
if (start_pin == 0)
goto stopwatch;
else
if (reset_pin == 0 )
s = t = 0;
goto start;
Target not created
#include<reg51.h>
#define msec 1
unsigned int
int s,t;
int i,j;
for(j=0;j<=50;j++);
mplex_delay(msec);
sec1_2=dig1%10;
sec1_1=dig1/10;
sec2_2=dig2%10;
sec2_1=dig2/10;
TMOD=0x01;
TL0=0xFF;
TH0=0xDB;
TR0=1;
while(TF0==0)
dig_ctrl_1 = 1;
digi_out(sec1_1);
dig_ctrl_2 = 1;
digi_out(sec1_2);
dig_ctrl_3 = 1;
digi_out(sec2_1);
dig_ctrl_4 = 1;
digi_out(sec2_2);
TR0=0;
TF0=0;
void serial()
TMOD = 0x20;
TH1 = 0xFD;
SCON = 0x50;
TR1 = 1;
while (1)
SBUF = sec1;
while(TI==0);
TI = 0;
void serial1_1()
TMOD = 0x20;
TH1 = 0xFD;
SCON = 0x50;
TR1 = 1;
while (1)
SBUF = sec2;
while(TI==0);
TI = 0;
void main()
while(1)
start:
start_pin = 1;
stop_pin = 1;
reset_pin = 1;
dig_ctrl_1 = 0;
dig_ctrl_2 = 0;
dig_ctrl_3 = 0;
dig_ctrl_4 = 0;
P2 = 0xFF;
s = t = 0;
display(0,0);
stopwatch:
if (stop_pin == 0 )
break;
if (stop_pin == 0 )
break;
t=0;
display(sec1,sec2);
serial(sec1);
serial1_1(sec2);
stop_pin = 1;
s = sec1;
t = sec2;
display(sec1,sec2);
if (start_pin == 0)
goto stopwatch;
else
s = t = 0;
goto start;
