[SOLVED] Error ran on make file
harerama
Member level 4
Bangalore,India
Hi.I written VHDL code once i ran my make file in GHDL simulator it gives below error.
ghdl1: fatal error: can’t open work/e~my file name.s for writing: No
such file or directory
Thanks in advance
Regards
Raghavendra
I think your work directory is not present. Create work directory before running.
Thanks.But i written in my make file below command to create work directory
GHDLFLAGS=--ieee=synopsys -fexplicit --workdir=work
Right, you have specified your work directory as work. But you have to create it by using mkdir work.
Thanks for your replies..I added mkdir work in make file but simulator error "*** missing separator"
Normally / (slash) is used as directory separator. Go through you make file and check.
