Error Memory in Quartus II
flote21
Advanced Member level 1
Hello guys!
I am trying to make a compilation of my project and I get this error:
Error (114016): Out of memory in module quartus_map.exe (4316 megabytes used)
Error (293007): Current module quartus_map ended unexpectedly
Anybody knows how to solve it?
Thanks.
Quartus has memory requirements depending on the FPGA type. Did you check it?
What?? No I have never checked that...what should I do?
What chip are you compiling for, and what are you system specs?
Basically, from the larger from Cyclone4 or arria 2 you need minimum 3 GB of ram. For stratix 4 + you need min 8 or 16 GB I think/
Problem solved. I reduced the memory of my VHDL arrays and it is working. I am using a cyclone IV and my PC has 12Gb of RAM and it is a Pentium I7. But I was running modelsim while launching the compilation in Quartus II. Maybe this was the reason.
If you modifed the VHDL to get this to work - it makes me think you've written some poor quality VHDL. Any chance you could post it, and we can assess?
Hi! Yes I can post my VHDL code:
  signal FPGA_MODEs     : std_logic_vector(FPGA_MODE'range);
  signal FPGA_MODE_l    : std_logic_vector(FPGA_MODE'range);
  signal RAW_DATAs      : std_logic;
  signal RAW_DATAss     : std_logic;
  signal VID_I_DAVr     : std_logic;
  signal BIN_SEL        : unsigned(2 downto 0);
  signal BIN_ADD1       : unsigned(15 downto 0);
  signal BIN_ADD2       : unsigned(15 downto 0);
  signal X_CNT_H        : integer RANGE 0 to 5000;
  signal Y_CNT_H        : integer RANGE -1 to 5000;
  signal X_CNT_V        : integer RANGE 0 to 5000;
  type ARRAY_2D is array (0 to 5,0 to 710) of unsigned (15 downto 0);
  signal	ARRAY_2Ds :	ARRAY_2D := ((others=> (others=>x"0000"))); -- intialize to 0
  signal BIN_SELr    : unsigned(2 downto 0);
  signal BIN_ADD3       : unsigned(18 downto 0);
  signal BIN_ADD4       : unsigned(18 downto 0);
  signal BIN_ADD5       : unsigned(18 downto 0);
  signal BIN_SAVE1      : unsigned(18 downto 0);
  signal BIN_SAVE2      : unsigned(18 downto 0);
  signal BIN_DAV        : std_logic;
BINNING_H_proc : process(VID_I_CLK, VID_I_RST)
  begin
    if VID_I_RST = '1' then
      FPGA_MODE_l  <= (others => '0');
		VID_I_DAVr   <= '0';
		BIN_DAV      <= '0';
      BIN_ADD1     <= (others => '0');
      BIN_ADD2     <= (others => '0');
		BIN_ADD3     <= (others => '0');
		BIN_ADD4     <= (others => '0');
		BIN_ADD5     <= (others => '0');
		BIN_SAVE1    <= (others => '0');
		BIN_SAVE2    <= (others => '0');
		BIN_DATA     <= (others => '0');
      X_CNT_H <= 0;
		Y_CNT_H <= -1;
		X_CNT_V <= 0;
	   ARRAY_2Ds <= ((others=> (others=>x"0000")));
      VID_F_SOI   <= '0';
      VID_F_SOL   <= '0';
		BIN_SEL     <= (others => '0');
		BIN_SELr    <= (others => '0');
    elsif rising_edge(VID_I_CLK) then
     -- Latch Dropping Factors + Reset Counters
	  VID_F_SOI  <= '0';
     if VID_I_SOI = '1' then
        FPGA_MODE_l <= FPGA_MODEs;  -- Latching Binning Mode
        VID_F_DARK <= VID_I_DARK; -- Latch Dark Info
		  if RAW_DATAss = '1' then
				VID_F_SOI  <= '1';
		  else
			  X_CNT_H <= 0;
			  Y_CNT_H	 <= -1;
			  VID_I_DAVr <= '0';
		  end if;
     end if;
     -- Valid Lines Management
	  VID_F_SOL <= '0';
     if VID_I_SOL = '1' then   -- New line
			VID_F_SOL <= '1'; -- Output every line
		else
	 		-- Increment ARRAY_2Ds_Y
			Y_CNT_H	 <= Y_CNT_H + 1;
			-- Reset ARRAY_2Ds_X
			X_CNT_H <= 0;
		end if;
    end if;
      -- Valid Pixels Management :
      -- Receiving 4 pixels on every clock cycle
      if VID_I_DAV = '1' then  -- New "4pixels"
		  BIN_SEL    <= BIN_SEL + 1;
        -- Binning 6x6
        if FPGA_MODE_l = "100" then
          if BIN_SEL = 2 then
            BIN_SEL <= "000";
          end if;
          if BIN_SEL = 0 then
				BIN_ADD1 <= resize(unsigned(VID_I_DATA(11 downto 00)), BIN_ADD1'length) + unsigned(VID_I_DATA(35 downto 24));
				BIN_ADD2 <= resize(unsigned(VID_I_DATA(23 downto 12)), BIN_ADD2'length) + unsigned(VID_I_DATA(47 downto 36));
				X_CNT_H <= X_CNT_H + 1;
			 elsif BIN_SEL = 1 then
 				BIN_ADD1 <= resize(unsigned(VID_I_DATA(35 downto 24)), BIN_ADD1'length);
				BIN_ADD2 <= resize(unsigned(VID_I_DATA(47 downto 36)), BIN_ADD2'length);
				ARRAY_2Ds(Y_CNT_H, X_CNT_H-1) <=  BIN_ADD1 + resize(unsigned(VID_I_DATA(11 downto 00)), BIN_ADD1'length);
				ARRAY_2Ds(Y_CNT_H, X_CNT_H)   <=  BIN_ADD2 + resize(unsigned(VID_I_DATA(23 downto 12)), BIN_ADD2'length);
			 elsif BIN_SEL = 2 then
				ARRAY_2Ds(Y_CNT_H, X_CNT_H)   <=  BIN_ADD1 + resize(unsigned(VID_I_DATA(11 downto 00)), BIN_ADD1'length)
				                                           + resize(unsigned(VID_I_DATA(35 downto 24)), BIN_ADD1'length);
				ARRAY_2Ds(Y_CNT_H, X_CNT_H+1) <=  BIN_ADD2 + resize(unsigned(VID_I_DATA(23 downto 12)), BIN_ADD2'length)
																		 + resize(unsigned(VID_I_DATA(47 downto 36)), BIN_ADD2'length);
				X_CNT_H <= X_CNT_H + 2;
			 end if;
			 if Y_CNT_H = 5 and X_CNT_H = 2 then -- Ready to provide RGB psixels!
				VID_I_DAVr <= '1';
				VID_F_SOI  <= '1';
			 end if;
		 end if;
	  end if;
	  -- Adding pixels using pipeline techniques
	  BIN_DAV  <= '0';
     if VID_I_DAVr = '1' then
	  BIN_SELr    <= BIN_SELr + 1;
		 -- Binning 6x6
         if BIN_SELr = 4 then
           BIN_SELr <= "001";
         end if;
			if BIN_SELr = 0 then
				VID_F_SOL <= '1';
			elsif BIN_SELr = 1 then
				BIN_DAV <= '1';
				BIN_DATA <= std_logic_vector(resize(ARRAY_2Ds(1,X_CNT_V), BIN_DATA'length) +
				                             ARRAY_2Ds(3,X_CNT_V)+ ARRAY_2Ds(5,X_CNT_V));
			elsif BIN_SELr = 2 then
				BIN_DAV <= '1';
				BIN_DATA <= std_logic_vector(resize(ARRAY_2Ds(0,X_CNT_V+1), BIN_DATA'length) +
				                             ARRAY_2Ds(2,X_CNT_V+1) + ARRAY_2Ds(4,X_CNT_V+1));
			elsif BIN_SELr = 3 then
				BIN_DATA <= std_logic_vector(resize(ARRAY_2Ds(0,X_CNT_V), BIN_DATA'length)   +
													  ARRAY_2Ds(2,X_CNT_V)   + ARRAY_2Ds(4,X_CNT_V)   +
							                    ARRAY_2Ds(1,X_CNT_V+1) + ARRAY_2Ds(3,X_CNT_V+1) +
													  ARRAY_2Ds(5,X_CNT_V+1));
			elsif BIN_SELr = 4 then
				BIN_DAV <= '1';
				BIN_DATA <= '0' & BIN_DATA(BIN_DATA'length-1 downto 1);
				X_CNT_V <= X_CNT_V + 2;
			end if;
			if X_CNT_V >= LIMIT_X_CNT_6R then
				VID_I_DAVr <= '0';
				X_CNT_V   <= 0;
			end if;
		end if;
	 end if;
 end if;
end process BINNING_H_proc;
You want to ARRAY_2Ds to be ram or what ?
So then this stuff expains why it delays around 1 hour to synthesis the code and when I try to make the fitter it does not work and Quartus II gives me an Error. What can I do to have the same working like an ARRAY_2D? Maybe a RAM?
yes, you can use a ram, but you need to work out how to organise it.
It takes a while to build those 68,256 bits in your array. If you have a 2D array that is say bigger than 1Kb (8x8x16-bit, sort of an arbitrary limit ;-)) then you're likely coding something that should be using a RAM block.
You mean that if I declare an array 2d like this:
type ARRAY_2D is array (0 to 7,0 to 1023) of unsigned (15 downto 0);
Should it work fine? Now everything is pow of 2....
No. Using a 2d array will not infer a ram from your VHDL. He is just saying you should probably re-design your code so that a ram is infered (ie. you probably want a ram, not a load of registers).
Did you read through the altera coding guidelines for ram inference? it explains quite clearly the code templates you need to infer different types of ram.
In hardware terms, a 2D-array isn't but an address mapping. It's quite easy to define an 1D-array with N*M elements and use a function to calculate the 1D index from 2D indices.
mmmm I have to think about this last issue....But I have another problem added and it is the space available in my FPGA (cyclone IV) I need a RAM of 65Kb to do a data processing and over 1Kb the FPGA is full...
Your 2D array needs about 60 -100 kbits (depending on the mapping method). Even the smallest Cyclone IV device has 270 kbits available. In so far there shouldn't be a problem if you finally manage to infer RAM instead of LE registers.
Have you looked at the synthesis report. That will show you what resources will likely be required. I suspect you are running out of LEs due to the 68Kb of 'RAM' i.e. flip-flops getting implemented by that 2D array.
Ok. I hae already solved my problem. I used several dual port RAMs and I have optimized the VHDL coding. Now everything is working fine and it fits in the FPGA. It was a bad practic VHDL designing.
Thanks a lot people!
