umairsiddiqui
Full Member level 2
i am currently debugging the cpu code, and try for first rough fpga
implementation (spartan3 starter kit). in cpu for a short cut,
i used a xilinx macro "adsu16".
i'm using Xilinx Project Navigator 6.1.03i. the design
properly synthsize, translate but fail on mapping
and shows following error and warnings.
please help with issue.
also i would be nice if any one of you write the code of adsu16 in
vhdl or verilog??? ;-)
Release 6.1.03i Map G.26
Xilinx Mapping Report File for Design 'top'
Design Information
Command Line : D:/installed-software/Xilinx/bin/nt/map.exe -intstyle ise -p
xc3s200-ft256-4 -cm area -pr b -k 4 -c 100 -tx off -o top_map.ncd top.ngd
top.pcf
Target Device : x3s200
Target Package : ft256
Target Speed : -4
Mapper Version : spartan3 -- $Revision: 1.16 $
Mapped Date : Tue Jan 31 02:27:29 2006
Design Summary
Number of errors : 1
Number of warnings : 16
Section 1 - Errors
ERROR:MapLib:87 - There are invalid FMAPs in the design. See warnings section
in map report for details of FMAP problems.
Section 2 - Warnings
WARNING:MapLib:541 - Internal signals in FMAP symbol
"u1/datapath/u2/u1/u1/XLXI_1/I_36_291" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I5) drive logic outside the MAP:
u1/datapath/u2/u1/u1/XLXI_1/SUB15
"u1/datapath/u2/u1/u1/XLXI_1/I_36_287" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I4) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_283" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I3) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_279" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I2) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_275" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I0) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_272" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I1) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_23" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I15) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_22" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I14) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_21" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I13) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_20" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I12) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_19" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I11) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_18" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I10) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_17" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I9) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_16" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I8) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_295" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I6) drive logic outside the MAP:
"u1/datapath/u2/u1/u1/XLXI_1/I_36_299" (output
signal=u1/datapath/u2/u1/u1/XLXI_1/I7) drive logic outside the MAP:
Section 3 - Informational
INFO:LIT:95 - All of the external outputs in this design are using slew rate
limited output drivers. The delay on speed critical outputs can be
dramatically reduced by designating them as fast outputs in the schematic.
INFO:MapLib:562 - No environment variables are currently set.
INFO:MapLib:535 - The following Virtex BUFG(s) is/are being retargetted to
Virtex2 BUFGMUX(s) with input tied to I0 and Select pin tied to constant 0:
BUFGP symbol "clk_BUFGP" (output signal=clk_BUFGP)
INFO:MapLib:159 - Net Timing constraints on signal clk are pushed forward
through input buffer.
