Hi All,
Am tried simulating the battery charger ic (MAX745) in OrCAD , i attached the screen shots of circuit and the resulting error screen about floating error. the circuit is drawn as such in MAX 745 datasheet.
expecting your valuable suggestions....
It seems that you do not have PSpice model for MAX 745 and several other components used in circuit. For PSpice simulation you must use parts available in ../tools/Capture/library/PSpice folder.
