error load program spi flash
pooya_BA
Junior Member level 2
I had a problem programming SPI flash. In the image below, you can see the circuit I designed.
I used "w25q64" for SPI flash and set the data width to 4, but I got the following error
INFO:iMPACT - Current time: 5/16/2021 9:30:37 AM
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 25000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file C:/Xilinx/14.1/ISE_DS/ISE/spartan6/data/xc6slx9_spi.cor.
'1': Downloading core...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1100 1110 1100
INFO:iMPACT:2492 - '1': Completed downloading core to device.
'1': IDCODE is 'ef4017' (in hex).
'1': ID Check passed.
'1': Erasing Device.
'1': Using Sector Erase.
'1': Erasing non-volatile quad-enable bit...
'1': Programming Flash.
'1': Reading device contents...
done.
'1': Verification completed.
'1':programming in x4 mode.
W25Q64BV Status Register Contents = 0x0200.
QUAD ENABLE : 1
STATUS REGISTER PROTECT 1 : 0
STATUS REGISTER PROTECT 0 : 0
SECTOR PROTECT : 0
TOP/BOTTOM PROTECT : 0
BLOCK PROTECT BIT 2 : 0
BLOCK PROTECT BIT 1 : 0
BLOCK PROTECT BIT 0 : 0
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
INFO:iMPACT - '1': Flash was not programmed successfully.
PROGRESS_END - End Operation.
Elapsed time = 78 sec.
I can program FPGA Spartan-6 but I have trouble programming SPI and I can't program the main program on this memory.
youve got a 1-bit datapath, but it’s trying to program in x4 mode, why?
In case 1x, I also encounter this error.
INFO:iMPACT - Current time: 6/7/2021 4:36:15 PM
Validating chain...
done.
'1':programming in x1 mode.
QUAD ENABLE : 1
SECTOR PROTECT : 0
Elapsed time = 77 sec.
Have you tried slowing down your programming clock speed?
Also, it doesn’t look like you’ve got your clock terminated properly. Look at this , page 42.
if you have JTAG defined ...first use JTAG to configure...and see everything works fine...
@bansalar
the Xilinx programmer uses JTAG to program the SPI flash connected to the FPGA SPI pins. It downloads the SPI flash programming FPGA image to bridge the JTAG to the SPI flash.
So they've already used JTAG to succesfully configure the part.
OP are you sure the SPI flash you selected is supported by Xilinx SPI programming?
@bansalar
Hello
I'm using "W25Q64BV" which is in the spi flash list.
--- Updated ---
Yes, I did, but I still got into trouble.
What was the solution?
In the same file that you sent, it said that you should connect pins M1 and M2 to ground and vcc, and also connect the INIT_B pin to a Vcc resistor, which I did not do and could not be programmed.
