Error in Simulation Process
Harjinder
Respected Sir,
I received a following error message when I run simulation in OPNET Modeler:
Network.mobile_node_4.ip), T (124.371), EV(1220806)
Error in IP routing process model (ip_dispatch) :
Unable to set size of final fragment.
Check simulation log messages from the IP model for more information.
Simulation Logging can be enabled/disabled in the Simulation Editor.
Kindly provide me solution for above mentioned error as soon as possible.Thanking you
