sj_helen
Newbie level 6
who can help me solve this sample hold circuit design problem???
ctrl1 for Sample Phase, ctrl2 for Hold Phase
I designed a opamp, which is used in the basic Sampel&Hold circuit.
The circuit will finish the sample and hold function by switching capacitors.
There are only 2 capacitors in the SH circuits. They are the two differential Sampling Capacitors which are connected to the differential inputs of opamp respectively.
In the Sample Phase, opamp's inputs are shorted and connected to Vcm. opamp's outputs are also shorted, but not connected to Vcm. Two capacitors are sampling differential input signals respectively.
In the Hold Phase, opamp's inputs and outputs are open circuits. Then the "signal" sides of capacitors are connected to opamp's outputs at the same side.
Theoretically, in the Hold Phase, opamp's inputs should be "Virtual Ground" with voltage value equals to Vcm. and the voltages at the differential outputs should be exactly the same as differential inputs.
Now comes two problems:
1,In the Hold Phase, voltage value of opamp's inputs are not Vcm, and a little higher than Vcm.
So how does this happened? and how to deal with this problem?
2,After Sampling and Hold for the first signal, when in the Sample Phase for the second signal, the opamp's outputs should be shorted and the voltage value should be Vcm.
However, simulation results did not prove this. The simulation shows if the already finished first signal is at the highest input signal level, then in the second Sample Phase, ouput voltage level is higher than Vcm; Whereas, if the finnished first siganl at the lowest value, the output level is lower than Vcm.
Thanks a lot.
Thanks a lot.
