ptshao
Junior Member level 1
During my simulation of CPW-fed monopole antenna centered at 2.45Ghz, the error occured. Please experter or experienced man check it for me. What does it mean? What should I do next step?
Thanks a lot!
cpwfed_monopole (D:/Program Files/project/)
glass_substrate
[error] Fast sweep setup, process abc3d : "WavePort1" mode 1 crosses cut-off in the specified fast sweep range. Consider splitting the sweep into multiple ranges. Use a port-only discrete sweep to locate the cut-off frequency.
[error] Simulation completed with execution error on server: Local Machine.
