error in gerber in cadence allegro ?
kabaleevisu
Advanced Member level 2
Chennai,India
Hi everyone,
usually i am doing board in mils format.but i have board which has (unit)mm format.i need to release the artwork (gerber) in allegro.by default inches.is i need to select inches or mm for gerber generation ??(because board format is mm). i got error in gerber generation please reply any one
  • error.txt
There are no errors listed in the report. Personally I would use metric gerber and drill file units, but it's not required.
Hi
thanks for your reply.but i get warning ?? please clear my doubt my board is mm for format.is i need to use mm or inches for gerber release ??
Warnings are normal you may ignore...There are no errors..
I would recommend you to generate gerber in the board units.
There might be no problem generating gerbers in inches , may be some accuracy problem in units conversion may occour.
