Error in CST Studio when importing secondary electron data?
khawarnadeem
Newbie
Newbie level 1
Hi.
On my university computer, I have access to CST Studio versions 2022 and 2024. I am trying to do some particle simulations, involving secondary electrons. But this version has the limitation that I cannot utilize GPU acceleration unless I import the data manually. But when I try to import the file, CST gives an error and the file closes. The SEY data file is a normal ASCII text file as recommended by CST for import purposes. The error log is as follows:
Output from stdout: This is the modeler 2024.1 Release from 2023-10-16 (change 1181985) Startup: 10.01.2024 15:39:40
Modeler affinity of main thread: 111111111111111111111111
thread setup step 1 (analyze system) : 12, 24 sockets : 1 cores per socket: 12 ht units : 2 acc. hw : 24 OSI log : CPUID: selected engine is 'Leaf 0xB detection'
apic ids : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27 apic ids (fallback): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27 from cpu registers: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27 fallback: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27
combined: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27
max id per cpu: 32
SMT mask: 1
Core mask: 1e Package mask: ffffffe0 set results: - packages: 1 - cores: 12 - smts: 2 generate core map, new implementation 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23 packages: 1 cores : 12 ht units: 2
thread setup step 2 (affinities) : 12 thread setup step 3 (openmp environment): 1024 --> 12 Modeler openmp threads: 12 Parallel ACIS is active. Starting 24 worker threads for ACIS. 4 blocks read in parallel from ACIS file. 4 top level entities in total.
How can I circumvent this? I need this simulation performed ASAP. Am I doing something wrong or is there a bug in CST that prevents SEY data import?
  • SEYAlum1.txt
LaTeX Commands Quick-Menu:
