bcaparna
Newbie level 1
- Joined
- Dec 2, 2010
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,290
Hello,
After running the momentum simulation and creating and updating the symbol, I placed the symbol from the library in a schematic file. After attaching the passive and active component s-parameter files to the simulated ports, when I try to run the s-parameter simulation, I encounter the following error:
Can someone explain the meaning of this error?
Thanks !
"(stdcmds.ael line 261, column 5)
Error generating netlist for "ATF52189_1350_1850_lib:ZX-60_MOM_SIM:schematic": Failed to create netlist:
In design `ATF52189_1350_1850_lib:ZX-60_MOM_SIM:schematic':
The instance `I__0' has 17 pins, but the view `ATF52189_1350_1850_lib:try_1:schematic' has 0 pins".
Thanks !
